Edit the chassis information to make changes to chassis-wide settings.
  1. In the Device Physical View tab, select the device.
  2. In the navigation pane, expand Configuration > Edit.
  3. Select Chassis.
  4. Select the Chassis tab.
  5. Edit the necessary options.
  6. Select Apply.
Chassis Field Descriptions
Use the data in the following table to use the Chassis tab.
Name
Description
Type
Specifies the chassis type.
ModelName
This parameter does not apply on all platforms.
Specifies the chassis model name.
BrandName
Specifies the chassis brand name.
PartNumber
Specifies the device part number.
SerialNumber
Specifies a unique chassis serial number.
HardwareRevision
Specifies the current hardware revision of the device chassis.
NumSlots
Specifies the number of slots available in the chassis.
NumPorts
Specifies the number of ports currently installed in the chassis.
BaseMacAddr
Specifies the starting point of the block of MAC addresses used by the switch for logical and physical interfaces.
MacAddrCapacity
Specifies the number of routable MAC addresses based on the BaseMacAddr.
Temperature
This parameter does not apply for all platforms.
Specifies the temperature of the device measured in degrees Celsius.
MacFlapLimitTime
Configures the time limit for the loop-detect feature, in milliseconds, for MAC flapping. The value ranges from 10–5000. The default value is 500.
AutoRecoverDelay
Specifies the time interval, in seconds, after which auto-recovery runs on ports to clear actions taken by CP Limit or link flap. The default is 30.
MTUSize
Configures the maximum transmission unit size.
The default is 1950 bytes.
MgidUsageVlanCurrent
Number of MGIDs for VLANs currently in use.
MgidUsageVlanRemaining
Number of remaining MGIDs for VLANs.
MgidUsageMulticastCurrent
Number of MGIDs for multicast currently in use.
MgidUsageMulticastRemaining
Number of remaining MGIDs for multicast.
DdmMonitor
Enables or disables the monitoring of the DDM. When enabled, the user gets the internal performance condition (temperature, voltage, bias, Tx power and Rx power) of the SFP/XFP. The default is disable.
DdmMonitorInterval
Configures the DDM monitor interval in the range of 5 to 60 in seconds. If any alarm occurs, the user gets the log message before the specific interval configured by the user. The default value is 5 seconds.
DdmTrapSend
Enables or disables the sending of trap messages. When enabled, the trap message is sent to the Device manager, any time the alarm occurs. The default is enable.
DdmAlarmPortdown
Sets the port down when an alarm occurs. When enabled, the port goes down when any alarm occurs. The default is disable.
PowerUsage
Specifies the amount of power the CPU uses.
PowerAvailable
Specifies the amount of power available to the CPU.
